MS G4 Series
7.5-10kW | Single Phase | 2/3 MPPTs
<30dB
20A
As the fourth generation of the proven single-phase, 3MPPT residential  inverter, the MS G4 series inverter comes with upgraded performance, reliability, functionality and safety, providing homeowners a more powerful and flexible solution for solar needs.
20A per string & 200% PV oversizing
AI-driven AFCI 3.0 for safety
Lightweight design for easy installation
Easy paralleling via GoodWe smart dongle Ezlink3000
<30dB
20A
Superb Safety & Reliability
GoodWe's MS G4 Series features a built-in rapid shutdown transmitter, enhancing system integration and safety. With optional AI-driven Arc Fault Circuit Interrupter (AFCI), the inverter is able to detect arc fault failure, sending alarms through monitoring systems and breaking the circuit simultaneously.
Built-in rapid shutdown transmitter
Type II SPD on both AC and DC sides
The MS G4 Series inverter supports mixed parallel connection with GoodWe DNS G4 inverters when paired with the GoodWe smart dongle EzLink3000. This enables flexible and efficient system expansion while reducing investment costs.
Flexible paralleling with GoodWe DNS G4 inverter
GW7.5K-MS-G40
Max. Input Voltage (V):
20
3/1
Weight (kg) :
Nominal Output Voltage (V) :
220 / 230 / 240, L / N / PE
GW8.5K-MS-G40
20
3/1
Weight (kg) :
GW10K-MS-G40
20
3/1
Weight (kg) :
GW7.5K-MS-G41
20
Weight (kg) :
220 / 230, L / N / PE
GW8K-MS-G40
20
Weight (kg) :
CONTACT FORM
Name
I am
Installer
Homeowner
Business Owner
PV Investor/Developer
EPC
Email
Country
City
Phone
Leave your message
Enter Verification Code:
