MIS Series
1.6-2kW I Single Phase I Microinverter
IP67
GoodWe's MIS Series microinverter is an ideal solution for residential and small commercial settings. Designed to work seamlessly with solar panels, each microinverter is paired with four panels, enabling individual panel tracking. The MIS Series microinverter is equipped with built-in WiFi and Bluetooth for easy setup and maintenance. Furthermore, it elevates monitoring and communication capabilities, empowering users to monitor each panel's performance in real time and identify any issues or inefficiencies. With GoodWe MIS, you will be able to maximize energy production and reduce energy losses, while also enhancing safety.
4-in-1 design for multi-angle rooftop
Max. DC voltage 60V
4 MPP trackers, module-level MPPT
Module level monitoring
IP67
Superb Safety & Reliability
MIS Series microinverters prioritize safety and reliability with a range of features. These include integrated grid protection relays, ensuring grid stability even during fluctuations. With a maximum DC voltage of 60V, they eliminate high DC voltage risks. The IP67 ingress protection shields them from harsh environmental conditions, and their design ensures there's no single point of system failure, guaranteeing uninterrupted operation.
AC protection relay integrated
Max. DC voltage 60V, eliminating high DC voltage risks
Optimal Performance
GoodWe's microinverter is crafted with individual MPPT control, resulting in a notable enhancement in power generation. The low startup voltage of 22V ensures continuous power generation from sunrise to sunset, optimizing solar energy utilization regardless of varying irradiation and weather conditions.
4
96.40%
96.40% max. efficiency
22
22V startup voltage
GW2000-MIS
Max. Input Voltage (V)
65
Max. Input Current (A)
4 × 16
Number of MPP Trackers/Number of Inputs per MPPT
4/1
Weight (kg)
6
1 / N / PE, 220 / 230 / 240
GW1800-MIS
65
4 × 16
4/1
Weight (kg)
6
GW1600-MIS
65
4 × 16
4/1
Weight (kg)
6
CONTACT FORM
Name
I am
Installer
Homeowner
Business Owner
PV Investor/Developer
EPC
Email
Country
City
Phone
Leave your message
Enter Verification Code:
