Lynx A G3 Series
14.3kWh | Low Voltage Battery
Lynx A G3 Series
IP20
Modular
The Lynx A G3 Series 14.3kWh battery is a high-capacity, low-voltage energy storage solution designed specifically for residential applications. It enables homeowners to store excess solar energy for use during peak demand hours or power outages, enhancing energy independence and self-consumption. Compatible with GoodWe low-voltage inverters, the Lynx A G3 Series ensures seamless integration and optimized system performance, providing a reliable and efficient energy storage experience for modern homes.
Support continuous 0.8C charging & 0.94C discharging
Support parallel connection for easy expansion
High-capacity 280Ah cells with long 6500-cycle lifespan
Perfectly matched with high-power inverters
Lynx A G3 Series
IP20
Modular
High Power Efficiency
The Lynx A G3 14kWh battery delivers high power efficiency with support for continuous 0.8C charging and 0.94C discharging, enabling fast and reliable energy flow to meet demanding usage scenarios. Its ability to connect in parallel allows for easy system expansion, ensuring both performance and flexibility as energy needs grow.
Sustained High Performance
The Lynx A G3 14kWh battery is engineered for sustained high performance, featuring high-capacity 280Ah cells that deliver a long lifespan of up to 6,500 cycles. Built to perform in harsh conditions, it incorporates advanced heating technology that ensures reliable operation even at temperatures as low as –20°C—making it a dependable choice for long-term energy storage in diverse environments.
Heating technology for reliable performance @-20℃
GW14.3-BAT-LV-G10
Usable Energy (kWh)
≥13.8
Nominal Voltage (V)
51.2
Max. Charge / Disharge Current (A)
224 / 260
Weight (kg)
125
Ingress Protection Rating
IP20
CONTACT FORM
Name
I am
Installer
Homeowner
Business Owner
PV Investor/Developer
EPC
Email
Country
City
Phone
Leave your message
Enter Verification Code:
