GoodWe's DNS inverter is equipped with Tigo's integrated Cloud Connect Advanced (CCA) and deployed with Tigo's TS4 Platform module-level power electronics. This solution has the ability to establish comprehensive communication with the Tigo Access Point (TAP). This reduces costs of the PV system which also benefits from all the advantages of Tigo, such as module-level monitoring, rapid shutdown, and optimization. All the data coming from both the inverters performance, as well as from Tigo, are integrated into GoodWe’s monitoring platform.
01
02
03
SYSTEM DETAILS
Tigo is an economical solution designed for shaded panels. It is not required to install optimaztions for all panels with Tigo solution.
ZERO-EXPORT (OPTIONAL)
The DNS inverter features a Zero Export function among its settings. This function can be activated with the use of a current transformer, which has the ability to detect any current flow to the grid and communicate this information to
the inverter.
PROTECTIVE DC ISOLATOR (OPTIONAL)
The GoodWe DNS Series also offers an optional package equipped with a DC isolator of level PV2, fully protected from other internal parts of the inverter and separated from the external environment. This is a design conceived to ensure
the safety of the electricians at the time of installation and maintenance.the inverter.
