UT Series
320/350kW | Three Phase | 12/15 MPPTs
Grid Friendly
IP66
The UT 1500V Series (320/350kW) is GoodWe's new three-phase string inverter designed to increase the profitability of utility-scale projects. Offering options of 12 MPPTs and 15 MPPTs, this series comes with a maximum string input current of 15/20 A, thus supporting bifacial 182mm/210mm module access. The Anti-PID and PID-recovery functions are available to mitigate and recover from PID (Potential Induced Degradation) effects. Moreover, designed for harsh outdoor environments, the UT inverter is built to withstand extreme temperatures, with a wide operating range of -35°C to +60°C. With enhanced safety, optimal LCOE, and ensured cost-effectiveness, the high-performance UT inverter provides a future-ready solution for utility-scale PV projects.
Anti-PID and PID recovery
IP66 and optional C5 corrosion protection
Dynamic reactive power response <30ms
Reactive power compensation at night
Grid Friendly
IP66
Superb Safety & Reliability
Type II Surge Protection Device (SPD) on both DC and AC sides protects the system from electrical fire and lightning hazards in extreme environments. Furthermore, the inverter offers IP66 rating for enhanced protection against dust and water, along with the option for C5 corrosion protection.
IP66 and optional C5 protection
Type II SPD for both DC and AC
Smart O&M
String level monitoring allows for complete observation of the energy system. Users can monitor each panel for smart and proactive maintenance.
Smart I-V curve scan
Higher Yields
UT Series is ideal for high-power 210mm modules by supporting up to 20A max. input current per string, which makes full use of power generated and guarantees LCOE for clients.
20
20 A max. DC input current per string
15
Up to 15 MPPTs
GW350KH-UT
Max. Input Voltage (V):
1500
40
12/2
Max. Efficiency :
99.01%
Nominal Output Voltage (V) :
800, 3L / PE
GW350K-UT
1500
15/2
Max. Efficiency :
99.01%
800, 3L / PE
GW320KH-UT
1500
40
12/2
Max. Efficiency :
99.01%
800, 3L / PE
GW320K-UT
1500
15/2
Max. Efficiency :
99.01%
800, 3L / PE
CONTACT FORM
Name
I am
Installer
Homeowner
Business Owner
PV Investor/Developer
EPC
Email
Country
City
Phone
Leave your message
Enter Verification Code:
