SECU-A Series
Low Voltage Battery
GoodWe’s SECU-A Series is a low voltage lithium battery, which is made from safe and durable lithium iron phosphate. The battery follows a modular design, making it extendable. As a plug and play device, it can be installed easily and quickly. Thanks to their safe design, the batteries can be connected together in parallel.
Safe & Reliable
Expandable Modular Design
Long Lifespan
6*SECU A5.4-20
Usable Energy (kWh)
32.4
Nominal Voltage (V)
51.2
Nominal Dis- / Charge Current (A)
100 / 100
Installation Location
Grounded / Cabinet
Enclosure Type
IP20
5*SECU A5.4-20
Usable Energy (kWh)
27.0
Nominal Voltage (V)
51.2
100 / 100
Grounded / Cabinet
Enclosure Type
IP20
4*SECU A5.4-20
Usable Energy (kWh)
21.6
Nominal Voltage (V)
51.2
100 / 100
Grounded / Cabinet
Enclosure Type
IP20
3*SECU A5.4-20
Usable Energy (kWh)
16.2
Nominal Voltage (V)
51.2
100 / 100
Grounded / Cabinet
Enclosure Type
IP20
2*SECU A5.4-20
Usable Energy (kWh)
10.8
Nominal Voltage (V)
51.2
100 / 100
Grounded / Cabinet
Enclosure Type
IP20
SECU A5.4-20
Usable Energy (kWh)
5.4
Nominal Voltage (V)
51.2
50 / 50
Grounded / Cabinet
Enclosure Type
IP20
