Elegant & compact
Fanless & quiet
The GoodWe 4-20 kW SDT G2 PLUS+ series inverter is specially designed for three-phase residential and small commercial projects. The integrated features of high efficiency allow for optimized power generation during the inverter's service cycle. With its lightweight and easy-to-install design, the SDT G2 inverter offers comfort and great convenience for operators and installers. Users can also take all-around smart control of energy management utilizing the featuring 24-hour load consumption monitoring enabled by GoodWe HK3000. Meet the perfect choice of maximum energy yield for residential and small-scale commercial usage.
Smart Shadow Scan with adjustable scan interval
Multi-protocol compatibility for smart home integration
Optional exchangeable DC Type II SPD & SPD failure alarm
Optional Arc Fault Circuit Interrupter (AFCI)
Elegant & compact
Fanless & quiet
Safety First. With optional Arc Fault Circuit Interrupter (AFCI), the inverter is able to detect arc fault failure, sending alarms through monitoring systems and breaking the circuit simultaneously. Optional Type II Surge Protection Device (SPD) on the DC side protects the system from and lightning hazards in extreme environments. GoodWe not only delivers efficiency, reliability, but security as well.
Optional AFCI reducing risks of fire
The SDT G2 PLUS+ Series can generate 10% additional power compared to the nominal output, increasing the overall yield. The high input current maximizes the generation thanks to its compatibility with high-power PV modules. The low startup voltage extends the generation time from early morning to late evening.
110% AC output overloading
Up to 16 A max. DC input current per string
98.4%
98.4% max. efficiency to minimalize energy loss
GW6000-SDT-20
Max. Input Voltage (V):
1000
Weight (kg) :
15.0
Nominal Output Voltage (V) :
400, 3L/N/PE
GW4000-SDT-20
1000
Weight (kg) :
15.0
400, 3L/N/PE
GW5000-SDT-20
1000
Weight (kg) :
15.0
400,3L/N/PE
GW20K-SDT-20
2/2
Weight (kg) :
26.0
380/400/415, 3L/N/PE
GW17K-SDT-20
2/2
Weight (kg) :
26.0
GW15K-SDT-20
2/2
Weight (kg) :
26.0
GW12KLV-SDT-20
800
2/2
Weight (kg) :
26.0
220/127, 3L/N/PE
GW12K-SDT-20
2/2
Weight (kg) :
23.5
GW10K-SDT-20
15
Weight (kg) :
20.5
GW8000-SDT-20
15
Weight (kg) :
20.5
