3.6-5kW | Single Phase | AC-coupled retrofit inverter (LV)
Fanless & Quiet
Elegant & compact
The GoodWe SBP series is the world’s first AC-coupled battery storage retrofit solution with UPS function for single-phase and three-phase systems. It can effectively upgrade any existing string inverter system by adding a backup battery. Capable of being grid-interactive, it allows users to store surplus power and sell it back to the grid when demand peaks and the price of electricity is at its highest. With a UPS-level switching function (switching time <10 ms), the GoodWe SBP provides an uninterruptible power supply to inductive loads such as air conditioners or refrigerators. It runs reliably under even the most extreme conditions with metal aluminium housing with IP65 protection.
IP65 ingress protection
Quality and robust components
<10 ms UPS-level switching
Fanless & Quiet
Elegant & compact
SBP Series can make a smart UPS-level switching to back-up mode in less than 10 ms, ensuring the critical loads experience no interruption. Supporting a variety of communication protocols, SBP series makes the integration of smart home systems for users' custom needs possible. Easy, smart, and intuitive.
SBP Series is equipped with fanless cooling to realize quiet operation for users' peace of mind. The elegant and compact design is perfect for indoor installation.
Elegant and compact design
GW5000S-BP
40~60
100/100
230
GW3600S-BP
40~60
75/75
230
3680
3680
