MS-US Series
5-11.4kW I Up to 3 MPPTs | Single Phase
MS-US Series
3 MPPTs
Built-in optimization
The MS-US Series is a high-quality PV solution engineered to meet the demanding needs of U.S. homeowners. Allowing a maximum 16 A input current per string and supporting up to 160% DC oversizing, this product was created for long-term, trouble-free lifetime operation with maximum energy production. Built-in optimization effortlessly addresses complex rooftops and shaded areas without the need for traditional module-level optimizers, which add cost and complexity to the system.
Built-in optimization eliminates the need for traditional optimizers
Integrated AFCI & Rapid Shutdown
160% DC input oversizing for maximum power production
Larger power classes offer installers more options
MS-US Series
3 MPPTs
Superb Safety & Reliability
GoodWe residential solutions deliver efficiency, reliability, and most importantly, security for homeowners. The MS-US has been designed to meet the stringent safety regulations of the U.S. market, including next-generation AFCI and rapid shutdown compliance to meet NEC 2017. The MS-US also offers optional of DC Type II Surge Protection with an event notification alarm, giving installers and homeowners greater peace of mind.
Optional DC Type II SPD & SPD failure alarm
Maximum Energy Production
The MS-US offers larger power classes with up to 16A max. DC input current per string, enabling greater module compatibility and system design flexibility for installers. Its integrated rapid shutdown technology speeds installation while 160% DC oversizing capability and wide voltage window offer homeowners greater energy production throughout the day. Built-in optimization effortlessly addresses complex rooftops and shaded areas without the need for traditional module-level optimizers, which can add cost and complexity to a system.
built-in
Optimization built-in
3
Larger power classes with up to 3 MPPTs
160%
160% DC Input Oversizing
GW11K4-MS-US30
Max. Input Voltage (V)
Max. Input Current per MPPT (A)/Number of Strings per MPPT
3/1
Weight
25.0 (kg) 55.1 (lb)
240 / 208
GW9600-MS-US30
3/1
Weight
25.0 (kg) 55.1 (lb)
240 / 208
GW7600-MS-US30
Weight
23.0 (kg) 51.8 (lb)
240 / 208
GW6000-MS-US30
Weight
23.0 (kg) 51.8 (lb)
240 / 208
GW5000-MS-US30
Weight
23.0 (kg) 51.8 (lb)
240 / 208
