MIS Series
800/799W I 2-in-1 Microinverter
IP67
GoodWe’s new 2-in-1 Microinverter is designed for both balcony and rooftop solar systems, combining a compact design with powerful performance. It maximizes energy yield through dual MPPT and broad module compatibility. With plug & play installation and advanced Wi-Fi Mesh networking, it delivers a seamless and efficient energy conversion solution — making clean energy more accessible for everyday use.
Plug & Play design for hassle-free setup
Dual MPPT with 18A input, compatible with larger modules
Effortless parallel with Wi-Fi Mesh self-organizing network
Reliable system-level solution
IP67
Superb Safety & Reliability
The MIS 2-in-1 Microinverter is built with safety at its core. Its rapid shutdown function instantly powers off in emergencies, while the AC rapid discharge feature lowers the voltage to safe level within 100ms after disconnection. The AC side is reinforced with three-level lightning protection and grounding, ensuring stability even during grid disturbances. With an IP67 waterproof rating, the MIS delivers long-lasting reliability and resistance to outdoor conditions, guaranteeing peace of mind for every household.
Rapid shutdown function for emergencies
Rapid discharge to safe level within 100ms
IP67 ingress protection
Optimal Performance
The MIS 2-in-1 Microinverter maximizes energy harvest in all conditions. With dual MPPT supporting up to 18A input, it delivers precise module-level tracking and adapts easily to high-power modules. Its low start-up voltage of just 15V ensures continuous power generation from sunrise to sunset, optimizing solar energy utilization under varying irradiation and weather conditions. Advanced WiFi Mesh parallel networking allows inverters to connect without a gateway, making rooftop installations faster, simpler, and more reliable.
2
2 MPP trackers, module-level MPPT
96.40%
96.40% max. efficiency
15V
15V startup voltage
GW0.799K-MIS-G10
Max. Input Voltage (V)
60
Max. Input Current (A)
2 × 18
Number of MPP Trackers/Number of Inputs per MPPT
2 / 1
Weight (kg)
3.4
L / N / PE, 220 / 230 / 240
GW0.8K-MIS-G10
60
2 × 18
2 / 1
Weight (kg)
3.4
CONTACT FORM
Name
I am
Installer
Homeowner
Business Owner
PV Investor/Developer
EPC
Email
Country
City
Phone
Leave your message
Enter Verification Code:
