Lynx C Series
60kWh | C&I Battery System
LiFePO4
Modular Design
GoodWe's Lynx C 60kWh outdoor battery system is tailored for small to medium-sized commercial and industrial (C&I) energy storage applications. Its modular design not only minimizes the impact of local failures but also allows for swift and straightforward module replacements. By seamlessly integrating GoodWe ET 15-30kW hybrid inverters into the IP55-protected battery cabinet, a compact, easy-to-install, and high-performance turnkey energy storage system is achieved. This powerful combination enables efficient energy backup, peak shaving, and streamlined load management. Moreover, the system supports the parallel connection of batteries and inverters, allowing for the expansion of the energy storage system size and enabling flexible configurations.
Remote monitoring & updates
IP55 and C4 corresion protection for indoor & outdoor installation
Compatible with GoodWe hybrid inverter ET 15-30kW
Support multi-cabinet parallel connection for easy system expansion
LiFePO4
Modular Design
Superb Safety & Reliability
The Lynx C 60kWh battery system is designed taking safety as a top priority.With its robust IP55 rating, this battery system is suitable for both indoor and outdoor installations, providing protection against dust and water ingress.
IP55 and C4 corrosion protection for indoor & outdoor installation
LFP battery cell
The Lynx C 60kWh battery system effortlessly integrates with the GoodWe hybrid inverter ET 15-30kW, ensuring seamless compatibility and optimal performance. Additionally, the innovative design allows for straightforward multi-cabinet parallel connections, offering a convenient pathway for system expansion.
GW60KWH-D-10 (Extension)
Usable Energy (kWh)
60
Nominal Voltage (V)
633.6
Max. Charge / Discharge Current (A)
96
Anti-Corrosion
C4 (Optional upgrade to C5)
Enclosure Type
IP55
GW60KWH-D-10
Usable Energy (kWh)
60
Nominal Voltage (V)
633.6
96
Anti-Corrosion
Enclosure Type
IP55 (Battery cabinet)
CONTACT FORM
Name
I am
Installer
Homeowner
Business Owner
PV Investor/Developer
EPC
Email
Country
City
Phone
Leave your message
Enter Verification Code:
