-20℃
10,000-cycle
The Lynx A G4 Series is a family of next-generation low-voltage energy storage solutions for residential applications. With a unified family design and flexible capacity options, it adapts to a wide range of household energy needs. Equipped with high-capacity 314Ah LFP cells and integrated DC-DC optimization technology, the series delivers reliable performance, scalable expansion, and seamless compatibility with GoodWe low-voltage inverters. Combining safety, flexibility, and affordability, the Lynx A G4 Series is designed for modern homes and distributed energy systems.
314Ah Cells, 10000 Cycles: Long-lasting reliability
Built-in DC/DC: Mix capacities. Mix old & new batteries
-20°C to 55°C Charge/Discharge: Reliable in diverse climates
130% Overload (10s): Supports peak loads
-20℃
10,000-cycle
Built with high-capacity 314Ah cells and enhanced overload capability, the system delivers reliable energy performance and long-term durability, providing confidence for demanding backup and off-grid applications.
From battery compatibility to installation options, the system offers greater deployment freedom with support for mixed battery configurations, both single-phase and three-phase inverters, and multiple mounting methods.
Wall & Floor Mounting: Flexible installation
Designed with multiple layers of protection, including an aerosol fire suppression system and IP65 protection, the system helps safeguard both the battery and the home across diverse residential environments.
IP65 & C5M Protection: Stable performance for long-lasting power
Aerosol Fire Suppression: Rapid fire suppression for enhanced safety
GW10.0-BAT-LV-G10
Rated Energy (kWh)
10
Max. Output Power (System) (kW)
5
Peak Output Power (System) (kW)
7.5kW (3s)
Cycle Life
≥10000
Ingress Protection
IP65
