LVSMT Series
12-35kW | Three Phase | Up to 6 MPPTs
Low voltage
98.8%
GoodWe's LVSMT Series three-phase inverter is designed with low voltage power input, and is an ideal choice for commercial installations. Developed as an efficient response to South American market needs for low-voltage inverters above 10 kW, this series is applicable to special grid voltage ranges within the region. With the GoodWe LVSMT Series inverter, the system configuration can be simplified by avoiding the installation of an expensive transformer, greatly reducing the initial investment costs of the system.
Max. Efficiency up to 98.8%
String level monitoring
IP65 ingress protection
Fuse-free design
Low voltage
98.8%
Friendly & Thoughtful Design
200V-650V wide input operating voltage range allows the solar system to start at an early stage, fully utilizing the daytime to maximize solar-powered energy generation and gain higher yield. The fuse-free design without consumable parts significantly reduces the operating time and costs.
200V-650V Wide MPPT voltage range
Fuse-free design
High Power Generation for High Return
With max. 15A DC input current per string, the LVSMT Series is compatible with different types of high-power modules, which ensures more solar power absorption, making it one of the most productive inverters on the market. With 130% DC oversizing, the system efficiency is enormously enhanced.
15A
DC input current 15A
130%
130% DC input oversizing
98.8%
GW35KLS-MT
Max. Input Voltage (V):
800
6/2
Max. Efficiency :
98.0%
Nominal Output Voltage (V) :
220, 3L/N/PE or 3L/PE
GW30KLS-MT
800
5/2
Max. Efficiency :
98.0%
GW12KLV-MT
800
3/2
Max. Efficiency :
98.7%
GW15KLV-MT
800
3/2
Max. Efficiency :
98.7%
GW20KLV-MT
800
3/2
Max. Efficiency :
98.8%
CONTACT FORM
Name
I am
Installer
Homeowner
Business Owner
PV Investor/Developer
EPC
Email
Country
City
Phone
Leave your message
Enter Verification Code:
