HCA Series
AC Charger | Single Phase - 7 kW | Three Phase - 11/22 kW
HCA Series
IP66 Design
Compact & Lightweight
The GoodWe HCA EV Charger allows homeowners to use the energy drawn from PV rooftops to charge electric vehicles (EVs), providing a highly cost-effective and environmental-friendly option for fast charging of EVs at home. With a GoodWe HCA EV Charger paired with a PV and energy storage system, EVs can be charged for free with 100% surplus solar energy. Moreover, by integrating seamlessly with GoodWe's monitoring platform SEMS, the PV and charging systems can be managed with a single app, allowing homeowners to monitor, control, and optimize EV charging anywhere. Its compact and lightweight design makes it easy to install and maintain.
Compatible with all branded EVs
Intelligent monitoring & scheduling
Easy to install and maintain
IP66 design for indoor/outdoor use
HCA Series
IP66 Design
Remote Control & Monitoring
The GoodWe EV Charger provides various communication options and integrates seamlessly with the cost-free monitoring platform SEMS. Therefore, system owners are able to intelligently monitor both the PV and charging systems, schedule charging processes, and optimize all household energy.
Manage PV and charging systems via SEMS
Modern & User-friendly Design
With wall-mounted and pole-mounted design as well as IP66 protection against all weather conditions, the GoodWe EV Charger is a great option whether you want to install it indoors or outdoors. Small, lightweight, and compact, the EV Charger can be installed and maintained in a hassle-free manner.
Wall-mounted or pole-mounted design
GW22K-HCA
Nominal Input Voltage (V)
400, 3L / N / PE
Nominal AC Grid Frequency (Hz)
50 / 60
Nominal Output Power (W)
22000
Nominal Output Current (A)
32
Dimension (W × H × D mm)
208 × 450 × 150
GW11K-HCA
400, 3L / N / PE
50 / 60
11000
208 × 450 × 150
GW7K-HCA
230, L / N / PE
50 / 60
7000
32
208 × 450 × 150
