AC EV Charger | Single-Phase & Three-Phase
7kW / 11kW / 22kW
The HCA G3 Series brings smart AC charging into the GoodWe energy ecosystem. Integrated with PV, storage and EzManager3000, it can prioritize solar power and respond to dynamic electricity tariffs to help reduce charging costs. Dynamic load management balances EV charging with other electrical loads to make better use of available power. Future V2X functionality could turn your EV from a passive load into an active energy asset—helping power your home and return energy to the grid. One connected system to make more of every kilowatt-hour.
AI Smart Charging
Future V2X Capability
Charge with Solar Power
Dynamic Load Management
OCPP 1.6J & ISO 15118
Built-in 4G
The HCA G3 brings EV charging into the wider home energy system. With EzManager3000, AI Smart Charging supports dynamic tariffs and five charging modes—Fast, PV, PV+BAT, Schedule and AI—to make better use of solar energy and lower-price periods. Dynamic load management adjusts charging power around other electrical loads when used with a compatible inverter or meter. The charger is also prepared for future V2X functions.
Supports Dynamic Tariff Charging
Prepared for future V2X functions
OCPP 1.6J connects the HCA G3 with compatible charging management platforms, giving operators more choice in how they manage charging. ISO 15118 supports standardized communication with compatible EVs, while built-in 4G² offers another way to get online. Future OCPP 2.0.1 / 2.1 support could create more possibilities for smart charging and energy management.
Compatible OCPP 1.6J platforms
ISO 15118 vehicle communication
Built-in 4G
Choose a tethered version with a 7.5 m cable or a socket version that lets drivers use their own cable. Mount the charger on a wall or on an optional floor stand to suit the site. For the socket version, the Type 2 Socket with Shutter (T2S) helps reduce accidental contact and keeps dust from entering the socket.
Tethered or socket versions
Wall-mounted or floor-mounted (optional stand)
GW22K-HCA-G30
Nominal Voltage (V)
400, 3L / N / PE
Nominal Frequency (Hz)
50 / 60
Rated Power (W)
22000
Rated Current (A)
32
Dimension (W × H × D mm)
235 × 360 × 110
GW11K-HCA-G30
Nominal Voltage (V)
400, 3L / N / PE
50 / 60
Rated Power (W)
11000
Rated Current (A)
235 × 360 × 110
GW7K-HCA-G30
Nominal Voltage (V)
230, L / N / PE
50 / 60
Rated Power (W)
7000
Rated Current (A)
32
235 × 360 × 110
