HCA G2 Series
AC Charger I Single Phase- 7kW I Three Phase- 11/22kW
GoodWe's HCA G2 EV Charger enables drivers to maximize solar energy usage when charging their electric vehicles (EV) through its smart phase switching function. It seamlessly integrates with the PV system's inverter and battery, allowing flexible charging options - either making the most of available solar power or a quick top-up from the grid, with customizable modes managed via the GoodWe SEMS+ app. Additionally, the HCA G2 supports multiple authentication methods, providing transparency on energy costs for account splitting and reimbursement, making it ideal for drivers, employers, and lease companies.
Easy installation and maintenance with a novel design
Compatible with all branded EVs
Dynamic load control
External emergency shutdown switch
Remote Control & Monitoring
The GoodWe HCA G2 EV Charger provides various communication options and integrates seamlessly with the cost-free monitoring platform SEMS+. Therefore, system owners are able to intelligently monitor both the PV and charging systems, schedule charging processes, and optimize all household energy.
Intelligent monitoring & scheduling
Manage PV and charging systems via SEMS+
Modern & User-friendly Design
With a wall-mounted and pole-mounted design and IP66 protection against all weather conditions, the GoodWe HCA G2 EV Charger is a great option whether you want to install it indoors or outdoors. Small, lightweight, and compact, the EV Charger can be installed and maintained in a hassle-free manner.
Easy to install and maintain
Wall-mounted or pole-mounted design
GW22K-HCA-20
Nominal Input Voltage (V)
400, 3L / N / PE
Nominal AC Grid Frequency (Hz)
50 / 60
Nominal Output Power (W)
22000
Nominal Output Current (A)
32
Dimension (W × H × D mm)
208 × 450 × 170
GW11K-HCA-20
400, 3L / N / PE
50 / 60
11000
208 × 450 × 170
GW7K-HCA-20
230, L / N / PE
50 / 60
7000
32
208 × 450 × 170
CONTACT FORM
Name
I am
Installer
Homeowner
Business Owner
PV Investor/Developer
EPC
Email
Country
City
Phone
Leave your message
Enter Verification Code:
