5-10 kW | Three phase | 2 MPPTs | Hybrid inverter (HV)
UPS-level switching
100% unbalanced
The GoodWe ET PLUS+ series is a three-phase high voltage energy storage inverter that enables enhanced energy independence and maximizes self-consumption through an export limit feature and time of use shifts for reduced electricity bills. Covering a power range of 5 kW to 10 kW, the ET series allows up to 110% overloading to maximize power output and features Uninterruptible Power Supply (UPS) to critical loads such as air conditioners or refrigerators within 10 ms. With UPS-level switching, the ET PLUS+ can provide grid-tied savings when the grid is up and off-grid independence and security when it is down or compromised.
98.2% maximum system efficiency
<10 ms UPS-level switching
100% unbalanced load
Wide battery voltage from 180V to 600V
UPS-level switching
100% unbalanced
Compatible with various high voltage batteries and offers flexibility and affordability to fulfil various customer demands.
Due to GoodWe’s cutting-edge patented technology, combined with high voltage batteries, the system’s efficiency can reach up to 98.2%, fully making use of solar energy.
98.2%
MAXIMUM SYSTEM EFFICIENCY
GW5K-ET
180~600
Max. Charging Current(A)
25
Max. Discharging Current (A)
25
Number of MPPTs
2
Number of Strings per MPPT
1
GW6.5K-ET
180~600
25
25
Number of MPPTs
2
1
GW8K-ET
180~600
25
25
Number of MPPTs
2
1
GW10K-ET
180~600
25
25
Number of MPPTs
2
1
