ET G3 Series
25-50kW | Three Phase | Hybrid Inverter (HV)
GoodWe ET G3 25-50kW
IP66
50dB
GoodWe ET G3 Series is a next-generation three-phase hybrid inverter designed for commercial and industrial energy storage applications. Combining high-performance energy conversion, flexible system scalability, and reliable backup capability, it enables efficient solar utilization and supports diverse energy scenarios. With advanced system integration and microgrid readiness, ET G3 provides a future-ready energy solution for businesses seeking greater energy independence and operational flexibility.
2 × 100A Dual Battery Inputs
Generator Peak Shaving
Starts More, Motor-Friendly
IP66
50dB
More Solar In, More Money Out
Smart energy starts with capturing every ray. Five independent MPPT trackers handle complex rooftop layouts and mixed orientations, while up to 200% PV oversizing lets you install more panels than rated — turning early mornings, late afternoons, and shaded strings into real kilowatt-hours. With dual 100A battery inputs, you're free to expand storage gradually, mixing existing and new battery banks rather than replacing everything at once.
5 MPPTs: More flexible sloar panel layouts
200% PV Oversizing: Make the most of your roof
2×100A Dual Battery Inputs: Mix, Match & Expand with Ease
Always On, Built to Endure
Backup that doesn't blink. 0 ms seamless on-grid/off-grid switching keeps critical loads online the instant the grid drops, while the motor-friendly design confidently starts pumps, compressors, and other high-inrush equipment without tripping. Generator peak shaving automatically trims demand spikes and fuel consumption.
0 ms Seamless Switching (under grid open-circuit conditions): UPS-Level Backup, Zero Break
Motor-Friendly Inrush Handling: Starts More, Powers Everything
Generator Peak Shaving: Run smarter. Burn less fuel
GW30K-ET-L-G30
150 ~ 650
100 / 100
42
Max. Apparent Power Output to Utility Grid (kVA)
GW25K-ET-L-G30
150 ~ 650
100 / 100
42
25
25
GW18K-ET-L-G30
150 ~ 650
80 / 80
42
18
18
GW50K-ET-G30
150 ~ 950
100 / 100
42
50
50
GW49.999K-ET-G30
150 ~ 950
100 / 100
42
49.999
49.999
GW40K-ET-G30
150 ~ 950
100 / 100
42
40
40
GW37.5K-ET-G30
150 ~ 950
100 / 100
42
37.5
37.5
GW30K-ET-G30
150 ~ 950
80 / 80
42
GW29.999K-ET-G30
150 ~ 950
80 / 80
42
29.999
29.999
GW25K-ET-G30
150 ~ 950
80 / 80
42
25
25
CONTACT FORM
Name
I am
Installer
Homeowner
Business Owner
PV Investor/Developer
EPC
Email
Country
City
Phone
Leave your message
Enter Verification Code:
