ET Series
25-50kW | Three Phase | 3/4 MPPTs | Hybrid Inverter (HV)
Peak Shaving
21A
GoodWe's ET Series inverters, available in 25-50kW capacities, are designed for commercial and industrial PV installations. These adaptable inverters seamlessly integrate into both on-grid and off-grid applications, facilitating parallel connections in either scenario.  When paired with the Static Transfer Switch (STS) Box from GoodWe, the inverter not only ensures dependable UPS-level switching to backup mode but also interacts with diesel generators to efficiently replenish batteries. Moreover, the ET Series is compatible with diverse battery capacities and brands, including the GoodWe Lynx C, offering a comprehensive energy storage solution.
Supports parallel connection in both on- and off-grid modes
Plug & Play installations
IP66 protection for outdoor installation safety
110% unbalanced output
Peak Shaving
21A
Superb Safety & Reliability
Type II SPD on DC side
AFCI optional
High Generation and Optimized Consumption
The ET Series has been improved for compatibility with high-power modules, with a maximum of 21A input current per string. The 150% DC input oversizing and 98.1% maximum efficiency, drive your inverter to its full capacity to increase your power output in lower solar radiation conditions.
150%
150% DC oversizing
21A
Max. 21A DC input current per string
98.1%
98.1% Max. Efficiency
GW50K-ET-10
200~800
100 / 100
42 / 32 / 42 / 32
50000
50000
GW40K-ET-10
200~800
100 / 100
42 / 32 / 42
40000
40000
GW30K-ET-10
200~800
100 / 100
42 / 32 / 42
30000
30000
GW25K-ET-10
200~800
100 / 100
42 / 32 / 42
25000
25000
CONTACT FORM
Name
I am
Installer
Homeowner
Business Owner
PV Investor/Developer
EPC
Email
Country
City
Phone
Leave your message
Enter Verification Code:
