ET Series
15-30kW | Three Phase | Up to 3 MPPTs | Hybrid Inverter (HV)
15A
Peak Shaving
GoodWe ET 15-30kW Series inverter is ideal for large residential or small commercial and industrial applications. As the core of the energy storage solution, the high-voltage inverters facilitate powerful energy backup and load management for optimized autonomy and reduced energy cost. The ET inverters also present peak shaving that balances power demand and grid power imported, to effectively reduce extra grid demand. Furthermore, thanks to dry contact in the inverter, external loads such as heat pumps can also be flexibly activated to optimize energy consumption. The series can be combined with a range of battery capacities and brands, including the GoodWe Lynx Home F.
Integrated dry contact for external loads
Plug & Play installations
Type II SPD on DC side
Up to 150% DC input oversizing
15A
Peak Shaving
Superb Safety & Reliability
Power export limit
High Generation and Optimized Consumption
The ET Series has been improved for compatibility with high-power modules, with a maximum of 15A input current per string. The 150% DC input oversizing and 98.0% maximum efficiency, drive your inverter to its full capacity to increase your power output in lower solar radiation conditions.
150%
150% DC oversizing
15
Max 15A DC input current per string
98.0%
98.0% max. efficiency
GW30K-ET
200~800
50×2/50×2
33000
30000
GW29.9K-ET
200~800
50×2/50×2
29900
29900
GW25K-ET
200~800
50×2/50×2
27500
25000
GW20K-ET
200~800
50/50
22000
20000
GW15K-ET
200~800
50/50
16500
15000
CONTACT FORM
Name
I am
Installer
Homeowner
Business Owner
PV Investor/Developer
EPC
Email
Country
City
Phone
Leave your message
Enter Verification Code:
