ESA-Athena Series
0.8kW/1.92kWh丨Single Phase丨Balcony All-in-One
IP65
Plug-in system
DIY
GoodWe's ESA-Athena Series is a compact, all-in-one solar plus storage system that turns your balcony into a personal power station. It seamlessly integrates an inverter, battery, and BMS into a sleek, space-saving unit. With up to 1500 W AC power, it delivers fast charging and reliable off-grid output for home backup and outdoor power needs. The stackable design allows effortless capacity expansion and adapts from a single panel to multiple arrays. Quiet and easy to install within minutes, ESA-Athena combines smart energy management with seamless Shelly plug integration, providing enhanced control over your power. It's a perfect combination of simplicity, style, and smart energy management.
Integrated inverter, battery, and BMS in one compact unit
4 MPPTs with 2400W PV input
Stackable to 9.6kWh - supports mixing old and new batteries
1500W off-grid output for reliable home backup and outdoor power needs
Works seamlessly with Shelly meters for accurate energy tracking
Built-in aerosol fire suppression system
IP65
Plug-in system
DIY
All-in-One Design & High Performance
The ESA-Athena Series integrates an inverter, battery, and BMS in one sleek, stackable unit—delivering powerful solar-plus-storage for balcony and home systems. With 1500W AC power, it delivers fast charging and for reliable home backup and outdoor power needs. 4 MPPTs supporting 2400W PV input ensure stable performance and exceptional energy efficiency. The stackable design enables expansion up to 9.6 kWh and supports compatibility between existing and new battery packs. Quick to install and easy to expand, ESA-Athena provides a simpler, more efficient way to power your home.
1500W AC charging power for fast charging
Superb Safety & Reliability
Safety and reliability are fundamental to the ESA-Athena design. It features an aerosol fire suppression system and a self-heating function that ensures stable performance from –20 °C to 55 °C. Certified by TÜV Rheinland, the system meets European safety standards and provides long-term peace of mind. Compatible with Shelly smart meters, it supports intelligent monitoring and self-consumption optimization — offering households dependable protection and smarter energy control in one robust solution.
Self-heating technology ensures reliable performance down to -20 °C
10-year warranty, designed for European homes
GW0.8/1.9-ESA-PS-G10
Max. Input Voltage (V)
60
18
4 / 1
Weight (kg)
26
220 / 230 / 240, L / N / PE
CONTACT FORM
Name
I am
Installer
Homeowner
Business Owner
PV Investor/Developer
EPC
Email
Country
City
Phone
Leave your message
Enter Verification Code:
