The GoodWe EO Series off-grid inverter is the ideal solution for those living in areas without power grids or experiencing frequent power outages. Its robust design guarantees durability even in harsh conditions, while the user-friendly setup minimizes installation costs. The inverter integrates dry contacts that can be connected to control loads and a generator, optimizing energy consumption and extending backup duration. It can operate with or without batteries and also allows multiple inverters to connect to a single battery system. Additionally, parallel connection is supported for expanded system capacity.
Integrated dry contacts for generator and load control
Compatible with lithium and lead-acid batteries
3-phase capability
Supports up to 3 units in parallel (10.5/18kW)
The EO Series off-grid inverter includes dry contacts that can connect to an external contactor or a generator. This enables precise control over load management and generator operation, allowing you to automatically turn loads and the generator on or off based on available energy.
Dry contacts for load control
Generator compatibility
The inverter is compatible with both lithium and lead-acid batteries, offering versatility in energy storage options. With a maximum efficiency of 97.0%, the EO Series ensures optimal performance and energy utilization, making it a reliable choice for diverse off-grid scenarios.
Max.efficiency of 97.0%
GW3500L-EO-BR
40~60
120 / 78
Max. Apparent Power from Utility Grid (VA)
4445
127
GW6000-EO
40~60
120 / 140
8050
220 / 230
