BTC Series
50/100kW | Three phase | AC-coupled retrofit inverter (HV)
100% unbalanced
UPS-level switching
The GoodWe BTC Series is an AC-coupled retrofit inverter designed for three-phase systems in distributed PV setups. It seamlessly integrates with high-voltage batteries, offering a voltage range of 200 to 865V. Featuring a straightforward Plug & Play modular design, the GoodWe BTC Series comprises four sections: DC/DC, DC/AC, STS, and EMS modules. This design facilitates easy installation and maintenance.
Featuring UPS-level switching with an impressive response time of less than 10 ms, the GoodWe BTC Series ensures a seamless and uninterrupted power supply for critical loads.
When combined with the GoodWe battery system Lynx C, which ranges from 101kWh to 156kWh, a highly efficient energy storage solution is formed. This combination is ideal for maximizing the utilization of renewable energy in distributed PV systems.
Modularized design
<10 ms UPS-level switching
100% unbalanced load
Built-in Type II SPD on AC side
100% unbalanced
UPS-level switching
Amazing flexibility for energy harvest
100% unbalanced output increases load flexibility, extends application scenarios, and maximizes self-consumption ratios. The powerful 110% continuous AC overload capacity guarantees robust energy supply in backup mode.
Powerful backup supply ability
System stability and safety guaranteed
With the ability to make a smart UPS-level switching in less than 10 ms, an uninterruptible power supply is always operational for critical loads. The lightning protection on AC side prevents voltage peaks from destroying connected devices and secures system reliability.
UPS-level switching
GW50K06-BTC
200~865
100/100
400, 3L / N / PE
55000
50000
GW100K06-BTC
200~865
100/100
400, 3L / N / PE
110000
100000
GW100K07-BTC
200~865
100/100
400, 3L / N / PE
110000
100000
GW50K07-BTC
200~865
100/100
400, 3L / N / PE
55000
50000
CONTACT FORM
Name
I am
Installer
Homeowner
Business Owner
PV Investor/Developer
EPC
Email
Country
City
Phone
Leave your message
Enter Verification Code:
