BT Series
5-10kW | Three Phase | AC-coupled retrofit inverter (HV)
Fanless & quiet
Elegant & compact
The GoodWe BT series is an AC-coupled retrofit inverter, which is able to upgrade existing three-phase on-grid PV systems to storage systems. The AC-coupled solution can transform any three-phase on-grid PV system into an energy storage system with batteries, enhancing grid independence and self-consumption. It is compatible with high voltage Li-Ion batteries ranging from 180 to 600V and is also equipped with UPS-level switching for a stable and reliable power supply.
<10 ms UPS-level switching
IP66 ingress protection
Quality and robust components
Fanless & quiet
Elegant & compact
BT Series can make a smart UPS-level switching to a back-up mode in less than 10 ms, ensuring the critical loads experience no interruption. Supporting a variety of communication protocols, BT Series makes the integration of smart home systems for users' custom needs possible. Easy, smart, and intuitive.
Friendly & Thoughtful Design
BT Series is equipped with fanless natural convection cooling to realize quiet operation for users' peace of mind. The elegant and compact design is perfect for indoor installation.
Elegant and compact design
With the capacity of 110% AC outpout overloading, BT Series can generate 10% additional power compared to the nominal output, increasing the overall yield.With a wide battery voltage range of 180-600 V, the inverter fits users' needs flexibly and makes the energy system construction much more effortless.
110% AC output overloading
Wide battery voltage range 180~600 V
GW10K-BT
180~600
25/25
400/380, 3L/N/PE
11000
10000
GW8K-BT
180~600
25/25
400/380, 3L/N/PE
8800
8000
GW6K-BT
180~600
25/25
400/380, 3L/N/PE
6600
6000
GW5K-BT
180~600
25/25
400/380, 3L/N/PE
5500
