IP66
<50dB
The SDT G3 Series inverter, with a 50kW capacity, delivers exceptional performance. It excels in being able to operate at an ultra-low noise level of under 50dB, ensuring its suitability for a wide range of commercial and industrial (C&l) applications, especially in noise-sensitive environments, such as schools and hospitals.
20A per string & 180% PV oversizing
AI-driven AFCI 3.0 for safety
Operate quietly at under 50dB
Compact design for easy installation
IP66
<50dB
With optional AFCI, the inverter detects arc fault failures, sends alarms through monitoring systems, and breaks the circuit. Type II Surge Protection Device (SPD) on both sides guards against lightning and other hazards.
Type II SPD on both AC and DC sides
The SDT G3 inverter is engineered for maximum energy yield, featuring 4 MPPTs, up to 98.7% efficiency, and 20A input current per string. With support for 180% PV oversizing, it captures more solar energy throughout the day for optimal system performance.
20A
180%
PV input oversizing
98.7%
Max. Efficiency
GW50K-SDT-C30
Max. Input Voltage (V)
40
4/2
Max. Efficiency
98.7%
