SBP G2 Series
3.6-6kW │ Single Phase | AC-coupled retrofit inverter (LV)
SBP G2 Series-SBP G2 Series
Elegant & compact
The GoodWe SBP G2 Series, is an AC-coupled inverter designed for retrofitting to existing single-phase or three-phase on-grid PV systems, providing an energy storage solution by adding a battery. The inverter is compatible with low-voltage batteries ranging from 40 to 60V such as the GoodWe Lynx Home U Series batttery, allowing surplus electricity to be stored for later use. The integrated plug-and-play features, compact design, and minimal weight provides easy installation, operation, and maintenance. The SBP G2 has the functionality of providing UPS-level switching to back-up mode in less than 10ms, ensuring a stable and reliable power supply.
Remote Shutdown
IP65 ingress protection
Elegant and compact design
<10ms UPS-level switching
Elegant & compact
SBP G2 Series can make a smart UPS-level switching to a back-up mode in less than 10ms, ensuring the critical loads experience no interruption. Supporting a variety of communication protocols, SBP G2 Series makes the integration of smart home systems for users' custom needs possible. Easy, smart, and intuitive.
GoodWe SBP G2 is suitable for both single-phase & three-phase systems, adapting to various architecture conditions of users. As an AC-coupled battery storage retrofit inverter, it can effectively upgrade an existing single-phase or three-phase on-grid PV system into an energy storage system by adding a battery.
AC-coupled battery storage retrofit solution
Suitable for both single-phase & three-phase systems
GW6000-SBP-20
40~60
120/120
220/230/240
6000
6000
GW5000-SBP-20
40~60
120/120
220/230/240
GW3600-SBP-20
40~60
75/75
220/230/240
3680
3680
