HCA Series
AC Charger | Single Phase - 7kW | Three Phase - 11/22kW
HCA Series-HCA Series
Compact & Lightweight
IP66 Design
With rising energy prices and lower feed-in-tariffs, solar system owners are now looking to maximise self-consumption and back-up of PV power, by combining GoodWe inverters and our Lynx Home Series battery options for a smart and highly efficient energy storage system. Owners with an electric vehicle (EV) can expand their system even further by including a GoodWe EV Charger to maximise their energy independence.
Easy to install and maintain
Compatible with all branded EVs
Intelligent monitoring & scheduling
IP66 design for indoor/outdoor use
IP66 Design
Remote Control & Monitoring
The GoodWe EV Charger provides various communication options and integrates seamlessly with the cost-free monitoring platform SEMS. Therefore, system owners are able to intelligently monitor both the PV and charging systems, schedule charging processes, and optimize all household energy.
Manage PV and charging systems via SEMS
Modern & User-friendly Design
With wall-mounted and pole-mounted design as well as IP66 protection against all weather conditions, the GoodWe EV Charger is a great option whether you want to install it indoors or outdoors. Small, lightweight, and compact, the EV Charger can be installed and maintained in a hassle-free manner.
Wall-mounted or pole-mounted design
GW22K-HCA
Nominal Input Voltage (V)
400, 3L / N / PE
Nominal AC Grid Frequency (Hz)
50 / 60
Nominal Output Power (W)
22000
Nominal Output Current (A)
32
Dimension (W × H × D mm)
208 × 450 × 150
GW11K-HCA
400, 3L / N / PE
50 / 60
11000
208 × 450 × 150
GW7K-HCA
230, L / N / PE
50 / 60
7000
32
208 × 450 × 150
