ET Series
15-29.9kW | Three phase | Up to 3 MPPTs | Hybrid Inverter (HV)
ET Series-ET Series
15A
Peak Shaving
The GoodWe ET 15kW-29.9kW Series inverter is ideal for residential, small to medium commercial and industrial applications. As the core of an energy storage solution, the ET inverter massively lowers energy costs by efficiently storing the solar power for flexible use and increasing self-consumption. Peak shaving balances power demand and grid power imported, to effectively reduce extra grid demand for the most cost-effective use for your property. When paired with the GoodWe Home F Series battery, this offers a one-stop shop solution for Three Phase systems. This series is available in 15kW, 20kW, 25kW and 29.9kW models.
Integrated dry contact for external loads
Type II SPD on DC side
Plug & Play installations
ET Series-ET Series
15A
Peak Shaving
Superb Safety & Reliability
Surge protections optional
AFCI optional
High Generation and Optimized Consumption
The ET Series has been improved for compatibility with high-power modules, with a maximum of 15A input current per string. The 200% DC input oversizing and 98.0% maximum efficiency, drive your inverter to its full capacity to increase your power output in lower solar radiation conditions.
200%
200% DC oversizing
15
Max 15A DC input current per string
98.0%
98.0% max. efficiency
GW29.9K-ET
200~800
Max. Continuous Charging Current (A)
50×2/50×2
Max. Continuous Discharging Current (A)
29900
GW25K-ET
200~800
50×2/50×2
27500
GW20K-ET
200~800
50/50
22000
GW15K-ET
200~800
50/50
16500
