ESA Series
29.9kW/60kWh | C&I Energy Storage System
ESA Series
All-in-One
Modular Design
GoodWe's ESA 30kW/60kWh all-in-one outdoor cabinet, designed for small to medium size commercial and industrial (C&I) energy storage applications, is a compact, easy-to-install, and high-performance turnkey solution energy storage system. The ESA Series seamlessly integrates battery, inverter, and BMS/EMS components into a single cabinet, complemented by air-conditioning units, along with fireproof and explosion-proof features.
Its modular design ensures minimal disruption in case of local failures, facilitating quick and effortless module replacement. Multiple cabinets can be connected in parallel to expand the size of the energy storage system, enabling flexible configurations.
Remote monitoring & updates
Fire suppression and explosion prevention design
Modular design with high power and energy density
Support multi-cabinet parallel connection
ESA Series
All-in-One
Modular Design
Intelligent storage solution for small and medium commercial applications
The energy storage system of the ESA 29.9kW/60kWh is composed of the GoodWe hybrid inverter ET 29.9kW and Lynx C 60kWh battery system. Available features include energy backup, peak shaving and load management.
Energy backup
Peak shaving
Expandable C&I Energy Storage System
With high power and energy density, ESA 29.9kW/60kWh all-in-one system supports parallel connections of inverters and battery cabinets, allowing seamless expansion as energy demands grow. This flexible solution helps businesses optimize energy use, reduce costs, and ensure long-term energy independence.
Supports parallel connection of inverters
Supports parallel connection of battery cabinets
GW29.9/60-ESA-ACPN-G10
Operating Voltage Range (V)
554.4 ~ 712.8
System Usable Energy (kWh)
60
Max. Apparent Power Output to Utility Grid (kVA)
29.9
29.9
