ESA Series
3-10kW/5-108kWh | Single Phase| Home Storage Solution (HV)
ESA Series
20A
IP66
*Initial stock may be supplied in a gloss white finish.
The GoodWe ESA Series is a fully integrated all-in-one solar and storage solution that combines inverter and battery in a pre-wired, modular design—making installation significantly faster and easier. Engineered for flexibility, the ESA system allows seamless expansion to meet evolving energy needs. 5kWh and 8kWh battery modules support 1C charging/discharging and can be mixed in a single stack up to 54kWh, with up to 6x stacks in parallel. The ESA provides UPS-level, full house back-up (63A) with no gateway needed. Models feature 2-4 MPPTs, each supporting up to 26A short-circuit input current. Safety features include 6-level battery protection and AI-driven AFCI 3.0 as standard, plus low noise levels of <30dB makes the ESA suitable for a wide variety of applications.
1C charge/discharge for rapid energy cycling
Fanless design for quiet operation, noise <30dB
Flexible battery mixing with different capacity or old&new batteries
Advanced 6-layer safety protection
ESA Series
20A
IP66
Optimized Performance
The ESA energy storage system is engineered for high efficiency and fast energy response, featuring a 1C charge/discharge rate that enables rapid energy cycling. With support for 20A input per string and up to 200% PV oversizing, it maximizes solar energy utilization even under varying conditions.
20A per string & 200% PV oversizing
The ESA energy storage system is designed to adapt to evolving energy needs with maximum flexibility. It supports mixing of old and new batteries, allowing easy system expansion. Each stack accommodates up to 6 battery modules, scalable to 54 kWh, providing tailored storage capacity for different scenarios. With 63A full backup output, ESA ensures reliable power supply for entire residential or small-scale C&l loads during outages.
Dual output ports for simplified installation & off-grid capability
Support full backup load with 63A output
GW9.999K-EHA-G20
350 ~ 550
35.6 / 29
20
Max. Apparent Power to Grid (VA)
9999
9999
GW8K-EHA-G20
350 ~ 550
31.6 / 23.2
20
8000
8000
GW6K-EHA-G20
350 ~ 550
23.7 / 17.4
20
6000
6000
GW5K-EHA-G20
350 ~ 550
19.8 / 14.5
20
GW3.6K-EHA-G20
350 ~ 550
14.3 / 10.5
20
3600
3600
GW3K-EHA-G20
350 ~ 550
11.9 / 8.7
20
3000
3000
