ES G2 Series
3-6kW │ Single Phase | 2 MPPTs | Hybrid inverter (LV)
ES G2 Series-ES G2 Series
Elegant & compact
The GoodWe ES G2 inverter is a single-phase hybrid inverter designed to increase self-consumption of generated solar energy, with the ability to control the flow of energy intelligently. The inverter has the functionality of providing backup modes with quick switching time in less than 10ms, that can cover heavy loads such as air conditioning. Its smart design also supports parallel connection for a dependable backup power supply. Installation is also easier and quicker thanks to a compact, lightweight design, with plug and play connection. The ES G2 is compatible with a wide range of low voltage batteries such as the GoodWe Lynx Home U Series battery. The ES G2 is the ideal inverter for homeowners looking to achieve a high degree of energy autonomy, reliable power supply, and lower energy bills.
Remote Shutdown
Optional AFCI on DC side
Smart load control with dry contacts
Elegant & compact
Friendly & Thoughtful Design
ES G2 Series allows for quick-connect Plug & Play on both AC and DC terminals that massively reduces the installation time, which makes it particularly efficient and easy to install. Its elegant and compact design makes it a perfect house fit-in choice for private homes.
Elegant and compact design
The power supply ability in backup mode supports large loads for critical operations. To use even more self-generated solar energy in your home, its maximum DC input current of 16A and compatibility with high-power modules generate more power and reduce the amount of electricity purchased from the grid to adapt to your needs.
Strong backup power supply
Maximum 16 A DC input current per string
High-power module compatibility
GW6000M-ES-20
40~60
60/60
6000
6000
GW6000-ES-20
40~60
120/120
6000
6000
GW5000M-ES-20
40~60
60/60
GW5000-ES-20
40~60
120/120
GW3600M-ES-20
40~60
60/60
3680
3680
GW3600-ES-20
40~60
75/75
3680
3680
GW3000-ES-20
40~60
60/60
3000
3000
