EHB Series
5-10kW │ Single Phase │ Hybrid Inverter
EHB Series EHB Series 3.6-6 kW Single Phase 2 MPPTs Hybrid Ready for Sale
16A
IP65
The EHB Series is a single-phase hybrid inverter designed to address the growing energy storage needs of the residential sector. Its plug-and-play, and lightweight design makes installation quick and easy. It also offers an integrated bypass feature for added reliability. The backup function is ideal for both new installations and retrofit projects, and can even be integrated into a micro-grid system, ensuring the normal operation of on-grid systems during blackouts.
<10ms UPS-level switching
200% PV input oversizing
In-built Type II SPD on both DC&AC sides
Plug and play installation
16A
IP65
Superb Safety & Reliability
Type II surge protection on both DC and AC sides is integrated to protect the inverter from lightning, providing upgraded safety and reliability for the PV system.
IP65 ingress protection
High Generation and Optimized Consumption
The EHB Series has been improved for compatibility with high-power modules, with a maximum of 16A input current per string. The 200% PV input oversizing, drive the inverter to its full capacity to increase power output in lower solar radiation conditions.
Max. 16A DC input current per string
GW5K-EHB-AU-G11
80~495
50/50
GW8.6K-EHB-AU-G11
80~495
50/50
8600
8600
GW9.99K-EHB-AU-G11
80~495
50/50
9990
9990
