314Ah
10,000 Cycles
GoodWe’s BAT-C Series high-voltage lithium batteries, available in 199-261kWh capacities, are designed for commercial and industrial (C&I) energy storage applications.
Paired with GoodWe ET hybrid inverters and STS, the BAT-C system delivers a highly integrated and easy-to-install solution for backup power, peak shaving, load optimization, and microgrid applications.
Advanced Safety Protection with 3-Hour Fire Resistance
Intelligent Liquid Cooling for Stable All-Climate Operation
Flexible & Scalable Energy Storage Expansion
Long Lifespan Design with High-Level IP Protection
314Ah
10,000 Cycles
A next-generation safety architecture that actively prevents, detects, and suppresses risks—delivering maximum protection and uninterrupted system reliability even under extreme conditions.
3-Hour Fire-Resistant Cabinet
Real-Time Gas & Pack-Level Monitoring
Integrated Fire Suppression System
Advanced liquid cooling combined with real-time cell-level sensing to ensure optimal performance, early fault detection, and stable operation across all climates.
Intelligent Liquid Cooling System
Cell-Level Real-Time Monitoring
Stable Operation from -25°C to 55°C
GW261.2-BAT-LCD-G10
Rated Energy (kWh)
261.2
Nominal Voltage (V)
832.0
Cycle Life
≥10000
Fire Safety Equipment
Aerosol (Pack & Cabinet Level)
Ingress Protection Rating
IP55
GW208.9-BAT-LC-G10
Rated Energy (kWh)
208.9
Nominal Voltage (V)
665.6
Cycle Life
≥10000
IP55
GW199.6-BAT-LCD-G10
Rated Energy (kWh)
199.6
Nominal Voltage (V)
665.6
Cycle Life
≥10000
IP55
GW199.6-BAT-LC-G10
Rated Energy (kWh)
199.6
Nominal Voltage (V)
665.6
Cycle Life
≥10000
IP55
