GoodWe's First Residential ESA Installation in Ireland
Europe Residential
0kWh 0kW
Project Overview
As the first installation of GoodWe residential ESA All-in-One system in Ireland, this residential project in Ennistymon, Co. Clare, features a 5 kW inverter paired with two 8 kWh batteries. With fast 1C charging and discharging, the system can quickly store solar energy and respond to changing household power needs. Support for 200% PV oversizing also allows greater PV capacity and helps increase solar generation potential under varying sunlight conditions. Its IP66-rated design provides protection against dust and water, while the compact all-in-one architecture helps simplify installation. The project marks the introduction of the ESA to Irish homeowners through an integrated solution designed for flexible residential energy use.
The Products
Residential Solutions
Bring the Sun Home
MORE
