Inverter capacity options under SDT G2 Series: 17kW/ 20kW/ 25kW
Advanced Ventilation System
SDT G2 inverters are designed to perform under extreme conditions. Excessive heat and component operation heat reduce the life and efficiency of the inverter. GoodWe’s SDT G2 series inverters are integrated with the best solution to this issue. The inverters are made tough and ready for extreme environments; with an advanced ventilation system, SDT G2 series inverter is able to dissipate heat efficiently and keep inverter operations efficient even in hot environments.
Data Security
The inverter has data breakpoint resuming function, which means it can re-upload data to the monitoring system when it reconnects to the server after going off-line. The data is encrypted during the transmission process and data on the server has backup. All these features ensure 100% data security.
Most Reliable Inverter Company
GoodWe inverters offer reliable operation and excellent performance and are well recognized by customers worldwide. GoodWe’s philosophy is to always create win-win partnerships with customers by identifying and integrating the most advanced components and techniques available while offering an unparalleled after-sales service. Technological innovation is GoodWe’s main core competence. With a large in-house R&D team in two R&D centers, GoodWe can offer a comprehensive portfolio of products and solutions for residential, commercial and utility scale PV systems, ensuring that performance and quality go hand-in-hand across the entire range.
GoodWe is a leading, strategically thinking enterprise which focuses on research and manufacturing of PV inverters and energy storage solutions. With an accumulative installation of 16 GW installed in more than 80 countries, GoodWe solar inverters have been largely used in residential and commercial rooftops, industrial and utility scale systems, ranging from 0.7kW to 136kW.
