2026-05-28
How to Maximise the Battery Rebate Post 1 May with the GoodWe ESA and Lynx Systems
How to Maximise the Battery Rebate Post 1 May with the GoodWe ESA and Lynx Systems-News
The Cheaper Home Batteries Program has shifted the way Australians use and control electricity in their homes. Over 400,000 batteries have been installed in homes and small businesses across the country since the introduction of the program. The changes to the rebate on 1 May 2026 not only reduced the upfront discount but also the way in which homeowners think about battery capacity. With smaller capacities now receiving a greater rebate return, the GoodWe ESA and Lynx F Series energy storage systems offer capacity flexibility to capitalise.
Changes to the Cheaper Home Batteries Program post 1 May
The success of the federal battery rebate was due to its generosity prior to May. The program was structured around the average home installing a 10 kWh system, but did not anticipate that most homes were installing 30 - 50 kWh. To ensure that the program could benefit as many homes as possible, the rebate changed to a tiered system on 1 May 2026. This tiered system, along with the reduced value of the STCs, now benefits smaller capacity batteries.
    ● First 14 kWh: 100% of the rebate
    ● >14 – 28 kWh: 60% of the rebate
    ● >28 – 50 kWh: 15% of the rebate
Retailers across the country are already seeing a shift away from larger capacity batteries.
How to maximise the battery rebate with the GoodWe ESA
With both the Single-Phase and Three-Phase GoodWe ESA All-in-One energy storage systems, homeowners have the flexibility to configure battery capacity around the new tiered structure of the Cheaper Home Batteries Program.
Unlike fixed-capacity battery systems, the ESA platform allows installers to mix and match battery modules to better align with household energy usage, future electrification plans, and rebate outcomes.
Currently, the ESA platform supports two battery module options:
    ● 5.1 kWh module (5 kWh usable)
    ● 8.3 kWh module (8 kWh usable)
These modules can be mixed and matched within the same system, allowing homeowners to tailor storage capacity to suit both their budget and energy needs.
Under the new rebate structure, many homeowners are aiming to stay close to the 14 kWh threshold to maximise the highest rebate tier. However, battery sizing is increasingly becoming a balancing act between rebate optimisation and long-term energy independence.
For example, a homeowner could install:
    ● 1 x 5 kWh module
    ● 1 x 8 kWh module
This would provide approximately 13 kWh of usable storage, allowing the system to remain fully within the highest rebate tier.
For households with larger overnight energy usage, EV charging, or greater backup requirements, larger configurations may still make strong financial sense.
A system configured with:
    ● 3 x 8 kWh modules
would provide approximately 24 kWh of usable storage.
Under the post-1 May rebate structure:
    ● the first 14 kWh would receive 100% of the rebate value,
    ● while the remaining 10 kWh would receive 60% of the rebate value.
While the rebate percentage reduces beyond 14 kWh, larger systems can still deliver substantial long-term savings by increasing solar self-consumption and reducing grid reliance.
This is particularly important as:
    ● feed-in tariffs continue to decline,
    ● electricity prices remain volatile,
    ● and more households electrify transport, heating, and cooking.
For many Australian homes, a larger battery system may still provide the strongest long-term value despite the reduced rebate percentage on additional capacity. Consider your additional power needs if you have or plan on adding any of the following:
    ● EV charging
    ● Pool heating
    ● Ducted air conditioning
    ● Home offices
    ● Full-home backup
The ESA platform also allows homeowners to expand storage over time. Rather than locking households into a fixed battery size, the modular design enables systems to grow alongside changing energy demands.
Beyond rebate optimisation, the GoodWe ESA simplifies installation through its integrated all-in-one architecture, combining:
    ● battery storage,
    ● hybrid inverter,
    ● battery management system,
    ● charger,
    ● and backup functionality
within a single platform.
Additional battery module capacities of 6 kWh and 9 kWh will be available later this year to further expand the flexibility of the ESA system.
The Lynx F G2 Series battery system configured for the battery rebate
The Lynx F G2 Series is a fantastic alternative for homes with an existing compatible GoodWe inverter. Rather than replacing the inverter entirely, homeowners can simply add battery storage to their existing solar system.
Like the ESA, the Lynx F G2 Series offers modular flexibility that works well within the post-1 May rebate structure.
Each Lynx F G2 battery module provides:
    ● 3.27 kWh nominal capacity
    ● 3.2 kWh usable capacity
A standard Lynx F G2 tower consists of between two and nine modules, allowing homeowners to scale storage depending on budget, energy usage, and rebate optimisation goals.
For example:
    ● 4 modules = 12.8 kWh usable
    ● 5 modules = 16 kWh usable
    ● 6 modules = 19.2 kWh usable
A four-module Lynx F G2 configuration sits just under the 14 kWh threshold, allowing homeowners to receive 100% of the available rebate under the new structure.
For households wanting slightly more storage, a five-module system would still maximise the rebate on the first 14 kWh, while receiving the reduced rebate percentage on the remaining capacity.
The flexibility available with the GoodWe ESA and the Lynx F G2 Series allows installers and homeowners to carefully balance:
    ● upfront system cost,
    ● rebate value,
    ● backup requirements,
    ● and future expansion potential.
Why capacity flexibility matters more than ever
The changes to the Cheaper Home Batteries Program have not reduced interest in batteries. Instead, they have changed the conversation around sizing.
Before 1 May 2026, many households simply installed as much storage as possible to maximise the rebate. Now, homeowners are increasingly looking for systems that can:
    ● fit neatly within rebate tiers,
    ● provide room for expansion,
    ● and align more closely with actual overnight energy usage.
This is where the modular design of the GoodWe ESA and Lynx F G2 Series stands out.
Rather than forcing homeowners into fixed battery sizes, both systems allow capacity to be tailored to the home. A household can start with a rebate-optimised configuration today and expand later as energy needs change.
For homes planning future EV charging, electrification upgrades, pool heating, or growing family demand, this scalability can make a significant difference.
The future of home battery storage
Australia’s battery market is evolving rapidly. While the rebate structure may have changed, the long-term value of battery storage remains strong. With electricity prices remaining volatile, feed-in tariffs continuing to decline, and more homes electrifying appliances and transport, battery storage is becoming less of a luxury and more of an energy management tool.
The GoodWe ESA and Lynx F G2 Series provide homeowners with something increasingly valuable in this changing landscape: choice.
Whether optimising for maximum rebate return today or planning for larger future energy needs, flexible modular battery systems are likely to become one of the defining trends of the post-1 May battery market.
