5-11.4 kW | Split phase | up to 4 MPPTs | Hybrid inverter (HV)
4 MPPTs
Smart Monitoring
GoodWe ES-US Series is a split-phase hybrid inverter designed to increase the self-consumption of your generated solar energy. GoodWe ES-US is compatible with high voltage (80-495V) batteries with a power capacity ranging from 5 kW to 11.4kW. With up to 4 MPPTs, the ES-US inverter seamlessly adapts to complex residential rooftops. Featured with rapid battery charge function, the series is perfectly capable of whole home backup. Equipped with an optional EV Charger function, the ES-US Series allows vehicles to be chargered with self-generated solar power under smart charging management.
Built-in optimization eliminates the need for traditional optimizers
Optional EV charger integration simplifies charging management
Integrated AFCI & rapid shutdown
Larger power classes offer installers more options
4 MPPTs
Smart Monitoring
The ES-US series is in a class of its own when it comes to delivering high quality, versatile PV and storage solutions to homeowners. With multiple options for storage including essential load backup and whole home backup, the ES-US leads the way in next-generation home energy management. Its integrated AFCI and rapid shutdown simplify installation and commissioning while giving homeowners maximum safety and investment security.
Options for storage including whole home backup
The ES-US offers larger power classes with up to 16A max. DC input current per string, enabling greater module compatibility and system design flexibility for installers. Its integrated rapid shutdown technology speeds installation while 150% DC oversizing capability and wide voltage window offer homeowners greater energy production throughout the day. Built-in optimization effortlessly addresses complex rooftops and shaded areas without the need for traditional module-level optimizers, which can add cost and complexity to a system.
Optimization built-in
Up to 4 MPPTs
GW11K4-ES-US20
80 ~ 495
Max. Continuous Charging/Discharging Current (A)
50/50
11400
11400
GW9600-ES-US20
80 ~ 495
50/50
9600
9600
GW7600-ES-US20
80 ~ 495
50/50
7600
7600
GW6000-ES-US20
80 ~ 495
50/50
6000
6000
GW5000-ES-US20
80 ~ 495
50/50
